electric fuel pump vapor locks on Ford V8 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2005, 01:32 PM
amateur gynecologist
I recently put an electric fuel pump on my '64 to replace the mechanical one and I like it a lot better but from time to time it vapor locks on me and I have to crack the line to bleed it between the pump and the carb.
Is there anything I can do to permanently correct the problem or should I just keep a flat tip screw stick in the glove box ?
Old 09-05-2005, 01:41 PM
DoubleVision's Avatar
Where`s the pump mounted? if it`s under the hood it`ll keep on vapor locking, all electrics are suppose to be mounted by the tank within a foot from the bottom of the tank, there made to push not pull.
Old 09-05-2005, 01:44 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
He's right.... Put it at the tank.
Old 09-06-2005, 05:59 PM
I mounted it on the driver's fenderwell above the horns !!!
Old 09-06-2005, 08:38 PM
lluciano77's Avatar
The Holley red pump works better mounted close to the carb. It is internally regulated.
Old 09-06-2005, 08:48 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I just bought a Holley Red pump.....The directions from Holley said to mount close to the fuel tank and preferably below it.
Old 09-07-2005, 07:03 AM
73oldsman's Avatar
Info; http://www.izook.com/tech/samurai/en...p/fuelpump.htm
Old 04-02-2006, 08:32 PM
Alright guys ! I got the thing moved within a foot of the tank, fired it up, it ran like a champ but then the fuel pump "kinda" died.
I bled it once, it ran for about five minutes, bled it again, it ran for about three minutes and died.
The pump was still humming but it wasn't pumping anything.
I dropped it once before I re-installed it plus it's six years old - cause of death old age/abuse ?
THANKS YA'LL !!!!
Old 04-02-2006, 09:49 PM
73oldsman's Avatar
I imagine there's an internal rubber baffle or sealing baffle inside the pump that probably dry rotted after sitting for six years. One pinhole in a pump diaphragm and it's DOA babee!
Old 04-03-2006, 09:17 AM
Technical Support Barry Grant
Electric fuel pumps are designed to push fuel, and should always be mounted as close to the fuel soruce as possible.
electric fuel pump install question bet on black Engine 5 02-01-2005 05:32 PM
Electric Fuel Pump Issue Eazy (Jax, FL) Electrical 1 06-29-2004 04:28 PM
Electric fuel pump location pcesak Engine 20 03-28-2004 02:23 PM
most popular electric fuel pump on this board? tony350ss Engine 17 10-01-2003 07:21 AM
Electric fuel pump, Push or Pull? hiimed Engine 4 02-15-2003 05:18 PM
