Electric Fuel Pumps
Hi fellow streetrodders @ gear heads. I have a problem. I have a 50 chevy tk. w/350 sb 60 over w/eldelbrock int, cam kit, @ carb. "pete jackson" drive. summit roller lifters,tk runs just fine. But, I can't seem to fine a fuel pump that lasts. I ran a "autozone" brand about 6 yrs. Switch to NAPA "carter" brand, went threw (2) pumps in less than 60 days.
They are inline pumps w/filter before pump. (napa says no problem w/pumps) So I switched to NAPA "POSI-FLO" brand. I'm going to try this one and see what happens Comments,suggestions,2cents welcome As always hotrodders BB is #1
The problem may be that the pumps don't like running against a dead head. You and I have done this for years with no apparent ill effects, but who knows how the manufacturers have cheapened the parts used in these current-day pumps?
If I were going to bullet-proof it, I'd run a return line from the carb to the tank and install a regulator in the return line. I'd choke the regulator down so that 5 psi would be delivered to the carb inlet. |
I ran a Holley Blue pump on my Blazer for several years by dead heading it. It was loud but worked fine. The only time I had a problem was when my voltage regulator went out and started sending 22v to my electric components. Needless to say, the pump wasn't the only thing that quit working...
A friend of mine ran a Holley Red pump with a return line and it worked well too. |
| Electric fuel pumps, Marine vs. Automotive | red ryder | Engine | 2 | 05-21-2009 02:12 PM |
| Fuel pumps and returns | 428ho | General Rodding Tech | 2 | 01-08-2007 08:39 PM |
| Electric Fuel Pump Issue | Eazy (Jax, FL) | Electrical | 1 | 06-29-2004 04:28 PM |
| electric fuel pumps | street rodder 1937 | Engine | 5 | 09-21-2003 06:44 AM |
| Help!! Blown out 5 fuel pumps | blown69stang | Engine | 4 | 04-26-2003 02:15 PM |
