Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - electric fuel pumps on carburator?
Old 11-10-2012, 08:49 AM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by lil-vulky View Post
ok thanking you lots should i set it at 6psi for the regulator or lower?
More pressure will not make more horsepower. What it will do is to overpower the needle and seat in the bowl of the carb and blow raw fuel into the intake manifold, creating a tuning nightmare. Shoot for 5 psi. You want high volume to prevent fuel starvation, with large diameter lines, not high pressure.
