Electric fuel pumps - Marine vs. Automotive - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2008, 12:52 PM
Wiki Edits: 49
Years ago I picked up a new in the box Carter marine electric fuel pump. It's a CRT-4389 which is rated at 72 gal per hour at 6 psi. I'm not building a race car so 6 psi should be plenty to feed the 3 deuces on my 331 hemi.
My question is.... what is the difference between Carter's automotive pumps and their marine pumps?? I'm thinking there is little if any difference but before I decide to use this on the deuce I would like some input and opinions.
Old 07-21-2008, 03:12 PM
ericnova72's Avatar
More for Less Racer
Marine pumps use powder-coated exterior cases and protective coated internal parts to improve corrosion resistance (think salt bath) . I beleive this is manated by our government, you have to use marine grade components on a boat.
Electric fuel pumps....for a boat WakBordr7387 Engine 5 10-23-2006 08:10 AM
Automotive and Marine Engines topfuel Engine 16 06-08-2005 08:19 PM
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 06:26 AM
Why does fuel pressure drops when electric fan turns on Palmtrees57chevy Engine 34 03-31-2005 11:47 PM
Electric Fuel Pump Issue Eazy (Jax, FL) Electrical 1 06-29-2004 04:28 PM
