electric kick down - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2004, 09:33 PM
electric kick down
I have an olds jetaway trannie with an electric kick down that will downshift when floored like most automatic transmission. The previous owner installed a button that does the same job. My question is should i just push in the button and release or should i hold it down? Does anyone have any experience with the "kickdown button" Also, would the th350 use an electric or mechanical kick down.?
Old 04-28-2004, 11:03 PM
BOBCRMAN@aol.com's Avatar
Use of the pushbutton would depend on the type of switch used and how it is wired. 350 turbo's normally have cable type, mechanical "kick down"
Old 04-29-2004, 11:41 AM
well all i know is its a little red button. Guess that doesnt give anyone much to go on. Ill examine it closer. Also should my foot be on the gas hard?, easy? not at all?
Old 04-29-2004, 08:29 PM
Does the button actually downshift the transmission or is it a manual switch for a switch-pitch converter?
Old 04-29-2004, 08:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
We need to determine if the tranny in question is what this ol tranny guy knows as a Jetaway or os a T-400 that was refered to as a jetaway
Old 04-30-2004, 06:39 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
A picture, or very detailed description would be a step in the right direction.
