Electric Or Mechanical
In your application there is no reason you couldn't use a mechanical pump.They flow more volume of fuel that will increase with engine rpm.I currently run a Keith Dorton mechanical pump on a 357ci 8-71 blown twin 750cfm holley's and have no problems.The pump flows 170gph.
The only electric fuel pump I have ever installed is on my own vehicle as a theft device, and it causes it to run out of fuel when hot and trying to pull a steep grade. I am going back to a mechanical pump when I get it out of moth balls. Every hotrod and all race engines I have built, been a crew chief of, or work on now in my shop, have mechanical fuel pumps. Just get a good one and enjoy.
fuel pump
The only advantage I can think of is constant fuel pressure/volume.And maybe with a race car making hard launches the fuel is pushed rather than pulled.It also can make more psi for running injection.But on the street I see no real advantage,I guess I'm just old school.
I wanted to try the electric fuel pump setup on my 496 BBC with an 850 CFM Speed Demon, so I installed a holley "blue" pump which I think is 110 GPH. It has never given any problems, but it sure was a pain in the *** to hook it all up. But if it is done right it really is a neat setup. I mounted the pump, filter, and relay to a diamond plate panel, then ran a supply line and bypass regulator (which any good electric fuel system should have). So all in all I had probably 36 feet of fuel line.
It is extremely noisy though, but I like to turn the key to the "on" position and listen to it wind up before I light the fires on that BBC. It is alot of fun to watch people take a step back when they hear that big motor about to light up. |
I would run a mechanical if you can. they are more durable, much quieter, and don't need any wiring.
if you want to or need to run electric, then get a mallory pump (comp110 or comp140). they are quiet and fairly durable if you use a filter before the pump and mount them low and near the tank. |
Whichever you choose, install a temporary fuel pressure gauge on the cowl so you can monitor pressure during driving. Take the reading off at the fuel line entry at the carb. Any current carb will run fine at 5 - 5 1/2 lbs. Any more than that and you risk overpowering the needle and seat and flooding the motor with fuel. If pressure at the carb is excessive, adjust your return regulator.
GM never saw the need for electric pumps on the L-88 427, LS-5 and LS-6 454, ZL-1 427, or DZ-302 engines just to name a few. Electrics are just plain un-necessary on the street.
....unless you have fuel injection.... |
Right!!! Like Gen V big block chevy's. They don't have anywhere to bolt one on.
| Oil leaking near fuel pump..what the heck??? | HotRodF100 | Engine | 13 | 01-08-2012 05:03 AM |
| Holley Electric Fuel Pump Woes | streetrodderbn | Engine | 12 | 02-12-2008 08:38 AM |
| 93 Plymouth Acclaim fuel pump relay | 78 monte | Electrical | 14 | 04-19-2007 03:09 PM |
| Electric fuel pump bad or not? | HotRodMan | Electrical | 4 | 09-10-2005 09:47 PM |
| Ford 1 and 2 piece fuel pump eccentrics | lluciano77 | Engine | 17 | 10-09-2004 10:58 PM |
