Electric Odometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2005, 06:19 AM
steve
Electric Odometer
Anyone have a suggestion on this problem? I have a '92 Buick Regal Custom 2 Dr. with the Stage II 3800 (supercharged). Anyway,the car is in mint condition and only 34K miles. Has every option offered on this particular model.
One of those options is a Digital display speedometer,but yet Buick must have been stumped at how to engineer a digital odometer at that point.
So it has the age -old analog type odometer. This thing will work at times.and then seems to jam or stick for 10-20 miles---then work again ?
Any ideas out there? It's very annoying,plus throws off keeping track of maintenance schedule. Thanks !
Old 09-29-2005, 06:48 PM
docvette's Avatar
Wiki Edits: 12
Speedo
Doc here,
Sounds like IT could be a couple of things..
Pull and check / replace the speedometer cable (s) and if you have a Cruise control you will have 2 of them ...be sure they aren't frayed and are properly lubed and seat in both ends properly..
If that is good pull the speedo, tear it down and check the magnetic motor for dirt and metal shavings sticking on the permanent magnet you can clean with a bit of real sticky tape..
Check the index pointer for freedom of movement, no contact with faceplate, or static parts...if found, carefully bend away from the obstruction..
last, rust, where ever you find it clean it, and before you re install it place a TINY bit of silicone lube on the area affected..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
electric fan cool rockin daddy Engine 2 06-12-2005 11:40 AM
Why does fuel pressure drops when electric fan turns on Palmtrees57chevy Engine 34 03-31-2005 11:47 PM
electric water pump for the street Z28cheverra General Rodding Tech 7 01-06-2005 08:51 AM
Opinions on electric fans and shrouds Centerline Hotrodders' Lounge 3 05-28-2004 02:37 PM
electric water pumps??? classic_chevy_guy Engine 3 10-24-2003 10:09 PM
