Electric Oil Pump... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2008, 07:25 AM
AmericanPackMule's Avatar
Last journal entry: Adolessent J.R.
What is the best way to connect an auxiliary oil pump. To use before the engine is started. I want the entire Oil System oiled, before cranking.
Old 03-05-2008, 09:50 AM
Are you talking about pre-oiling before the initial startup following overhaul, or before EVERY startup?
JA
Old 03-05-2008, 11:56 AM
JA
before EVERY startup ~ I want to Place it under the hood. WHEN I PUT THE ENGINE IN. ( NEW ENGINE ~ I RAN IT ABOUT 10 MIN.@2,000 R.P.M. With 50 Lbs. Oil Pressure. With 20 /W ) AFTER PRE-OILING
Granger has the pump I'm Get'n For $99.00.
I'm Wondering weather I can put it in @ the Pressure Gage or weather I should put it in @ Oil Filter With An Oil Cooler...
'72 /429 c.i.
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 09:51 PM
BBC oil pump question JamesRS Engine 11 07-13-2012 02:14 PM
Please help to diagnose- engine with no oil pressure. Oil pump failed? killerformula Engine 4 12-26-2006 11:25 PM
Oil Pump Problem??? riesman20 Engine 11 05-25-2004 11:06 PM
oil pump drive shaft. christopher406 Engine 7 01-30-2003 06:42 PM
