electric parking brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2012, 03:53 AM
Hi has anybody done one?
I have heard of the ebrake system but I cannot find details of cost or supplier?
many thanks for any help
Old 01-19-2012, 05:24 AM
Irelands child's Avatar
Anything but a mechanical may be illegal in your state. Even Total Performance offered a hydraulic version - which they finally made into a mechanical after it was proven to be illegal in most states.
The electric parking brake was actually hydraulic, actuated by holding the regular brake down fairly hard, the flipping a switch for an inline electric solenoid. The last one I personally saw was in the late '50s- early '60s
Old 01-19-2012, 06:03 AM
We are allowed to use an electrial device to pull on the existing manual cables.
I have seen a few examples of actuators but cannot seem to find a supplier.
Old 01-19-2012, 08:48 AM
The newer Cadillac CTS models with the supercharger have this one. $250 or so @ the Cadillac dealership.
The Following User Says Thank You to Deuce For This Useful Post:
Old Fool (10-05-2012)
Old 01-19-2012, 10:55 AM
ogre's Avatar
the 'Duracell Project'
thanks for posting that one deuce.
i may have to look into it for truk
Old 01-19-2012, 12:11 PM
Joe G's Avatar
Registered user
I installed an electric parking brake actuator in a car a while back. I'm not sure what the brand name of the system was, but I got it from a local company that rigs vans for handicapped drivers. It worked great, but it was about $800, and when I opened it up to see how it worked, it was just a modified GM window regulator.
Hope this helps.....
Old 02-19-2012, 12:03 PM
electric e-brake
I just returned from a cross country trip in a buick locrose, to put on the park brake you have to flip a switch , to release the brake ,flip another switch, also when you put in reverse the mirrors adjust to help with parking , I'd check with Gm dealers.
Old 02-19-2012, 11:15 PM
How about one of these http://www.surpluscenter.com/item.as...tname=electric
Old 02-20-2012, 03:40 AM
Wiki Edits: 31
Electric parking break is also standard on the new Subaru Legacy. Hit the brakes, and flip the switch to lock and unlock them
Old 10-04-2012, 03:48 PM
Check out this one.
The Push Button E-Brake
This company won product of the year at the NSRA nationals. It comes with everything in a compact design (important for small chassis). It's msrp is $449 only about $80 more than some of the foot pedal systems. Plus it's all regulated by a micro computer so it won't keep pulling and rip up your brake system. Worth checking out.
Old 10-04-2012, 04:48 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
The surplus actuator looks good! That's what the E-stop company is using, or something similar. They just have a limiting circuit. The "microcomputer" is probably a BASIC Stamp or Arduino board with some type of strain gauge -- probably measures current draw of the actuator. Simple -- motor starts to strain and draw more amps, computer cuts it off. Not sure if that's how they do it, but has to be something like that. They might have a more complicated and costly way to do it.
With a 4" stroke actuator you would need something to prevent pulling too hard and frying the actuator or wiring to it, or pulling something loose. A simple limit switch would work, but would need adjusting on occasion. I know the brake cable needs some travel, but 4" sounds excessive. I don't think the cable actually pulls but maybe an inch. The pedal or pull handle travels more, but they are made to have more leverage so they don't require a lot of effort to set the brake. There are several 1.5"-2.25" actuators on the surplus site (Surplus Center) that would work and are pretty cheap. A few are electric seat motors. No pull rating, but they move my *** and seat along just fine, I'm sure they would pull a park brake cable hard enough! I like the 1.5" 250 lb rated actuator for this application, if a 1.5" pull is enough.
Has anyone here done an Electric Parking Brake? Ripped Suspension - Brakes - Steering 18 10-09-2012 08:51 AM
Parking brake 80Chevyk10 Suspension - Brakes - Steering 3 11-09-2011 07:02 PM
Parking Brake help for a 67 GTO 67goat455 Suspension - Brakes - Steering 3 11-10-2007 10:28 AM
Mecanical disc brake caliper for parking brake? bigun Suspension - Brakes - Steering 4 12-15-2005 08:43 PM
parking brake broncoII88 Suspension - Brakes - Steering 4 04-05-2005 07:37 PM
