electric power brakes
I've been around a couple and they work very good. there is an electric pump and accumulator mounted remote and a rather large aluminum master cylinder to mount on the firewall or under the floor. The only minus in the formula is they are very expensive "around $1600". Go for it if you can afford it.
I'd probably would consider a Kugal for fit as they have several unique mounts for master cylinders. I'm running a foreign car master cylinder mounted in back with a long pushrod in my roadster.
