Electric power brake booster - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-24-2009, 04:22 PM
Building Your own brake system
Hi Mike
A hydro boost can be mounted in any position frame rails included.
A remote master cylinder is no problem but you should use a 1.125 dia piston power brake master.
The pedal feel is very light a touch of your foot on the brake pedal will stop most rods out there in normal driving.Its just like a Ford super duty with a diesel motor. As far as distance goes it would depend on what other baking components you have installed. A mid 80s corvette 6 piston caliper large rotor will stop like a super car with a hydro boost. I dont want to get in trouble with this site but you contacted me so www.tallonhydraulics.com
will help you find what you need and can build what you want just contact them through the web site.
  #17 (permalink)
Old 09-25-2009, 04:08 PM
Electric Boost
Yes there is electric boost. It was used where there was cramped space under the hood in the normal area of the master cylinder. I first saw it on a Jeep Cherokee.
This is not something you would want to adapt into a project. Hydroboost itself is a fabulous mature design when it uses a power steering pump to supply the > 1000 psi fluid pressure as the boost power source. The problem with the electric driven pump power source is that the pump design is below poor.
They chose to use a very cheap electric brush motor that is below the quality of say a electric window motor. They were not careful with fluid connector choices, pump body was aluminum, etc. The pump would strain to reach the design pressure.
How it was supposed to work: The pump would come on and pump fluid until a pressure switch was satisfied at 1200 psi. The pump motor would shut off until the pressure dropped back down (the brakes were pressed). So far things are ok until: Something leaks, the cheap pressure switch contacts stick or don't make, fluid runs low and the system stays on until the motor smokes or the pump gets hot enough to melt the "o" ring seals. The units are more expensive than power steering systems because they are constantly failing so the supply of rebuilds runs low and the supply of "cores" run low - driving the core charge through the roof.
I had considered using the brake fluid pump from an ABS system as a power source because they are good quality but, decided not to chance using a motor /pump that was supposed to come on a few times a year for continuous use. Stopping is just too important.
Hydroboost - Yes *** electric boost no!
John
  #18 (permalink)
Old 12-02-2009, 05:57 PM
ogre's Avatar
the 'Duracell Project'
hydroboost
i realize this thread was started in 05, but i thought i would put
my info in for future readers.
project 58 chevy pickup: mustII front disc & 86 trans am rear disc brakes.
i wanted power brakes and a shaved firewall. hanging pedal with 12" vacume booster wouldn't work.
frame mounted 7" vacume booster didn't fit my needs (weak *** legs). original master
cylinder was under floor, frame mounted.
i found a hydroboost out of an 03 mustang gt, junkyard purchased for $100.
fabbed the bracket and made a plate to weld in my frame that the bracket would bolt to.
i used my stock swing arm and pedal.
my truck has power steering anyway, picture above is before plumbing the hydro lines.
i did not move the pivot points of the original swing arm. but i was able to cut 3" out of the pedal height,
thus lowering the pedal to the floor (remember those weak *** legs). this helped considerably.
i have only driven my truck 20 miles before putting it in the shop for the winter (and to finish the bed).
but i can tell you that they work rather well.
  #19 (permalink)
Old 12-08-2011, 06:38 PM
Can't stress enough to rebuild
I can't stress enough to rebuild brake units that come from the junkyard, units are available but, their quality: depends on the mileage, and depends on how the previous drive drove the car. The Hydroboost is the one thing really what we are going all the way with for everything, but, the rubber can be swollen, and it is just so easy to get a rebuild. It is the best things since sliced bread but they should be rebuilt every 100,000 to 150,000 miles.
Be sure of the reputation of the rebuilder, because there are more than a few companies that we are aware of these days that repaint or polish up the outside of a an old unit and sell it as rebuilt (trust me on that). If you wonder why a seller has them for a fraction of what the other sellers have them for, then they are scamming you, and that goes for most things.
  #20 (permalink)
Old 12-08-2011, 09:06 PM
Electric Brake Answers
As many of you seem to have figured out, the Electric Brake was from a Jeep, there were a few other different inceptions of 'electric brakes', as in the Turbo Buick Powermaster, and the electric brake unit on the Ford T-bird SuperCoupes. You can see videos here where we covered both of those
Both of these units were used to try and work around the complete lack of vacuum that the two cars had because of the supercharging they came with.
No vacuum + vacuum booster = fast car with no brakes. So Bob at Power Brake Service developed what is now being called the Electric Brake in the mid to late 80's, because it seemed to solve the lack of vacuum problems that the muscle cars and hot rods we normally see have, because of their blowers and huge cams.
The advantage of being in business for 60 years is that your customers update you on how products worked out, and you can adapt to improve. After a while our customers were telling us that the electric motors would burn out faster than they would expect and the units would fail... after a while. Bendix stopped making the new units, and there was nobody making parts to rebuild it. No new units and no parts meant that it wasn't a viable option. The pressure switches, accumulators, and pumps were all prone to failure, and three sources of failure is not something that we would want to sell.
These days, with no major manufacturer making new units, and nobody making rebuild kits, means that there are no new units available to anybody anywhere, and there are absolutely no rebuilt units anywhere for anybody to adapt to their other application. They are also not making Powermaster parts (go ahead and find out how the Grand National guys feel about that), and ATE doesn't care to make the T-bird units again.
That means that there are no legitimate electric booster units coming from PBS (us) SSBC, Baer or anybody. There are only un-rebuilt used units available. There are new casting that are being made, but there are only used internal parts place in them (the casting doesn’t stop the car, the parts do). We've thought about selling them again since they seem popular, but we don't know where to start since whatever cores are available have been over rebuilt and machined. It is a cold hard fact for the few of us performance brake companies… and the electric vacuum pumps are fighting a loosing battle against the complete lack of vacuum in a performance engine. The New Delco Moraine 11 inch boosters that you can buy, aren’t being made by Delco, they are stamped under license in China, making them un-American for your American classic. For the last twenty years the big companies have been using crimped cans, not twist off, for vacuum boosters, so they can only be rebuilt twice before the out can is trash. Finally, the 7 inch vacuum boosters that people are putting on only put out between 400-600 psi, and calipers require 1200 to operate, so they are dangerous. Hydroboosts are the perfect solution, but are on the expensive side for a lot of people. Pretty frustrating, isn’t it?
  #21 (permalink)
Old 12-08-2011, 09:43 PM
I didn't get those youtube embeds right:
  #22 (permalink)
Old 12-08-2011, 09:44 PM
Powermaster
  #23 (permalink)
Old 01-08-2012, 01:16 AM
396375's Avatar
If it isn't fast,it isn't mine
The Powermasters are still available.Kirban Performance stocks them.They are rebuilds from Cardone and do carry a lifetime guarantee.A lot of the rebuild parts have been improved over the years.The accumulator bowl and pressure switch are much better.The core charge was $75 last time I looked.If you get a good one they work well.The only problem is finding a good one.It's hit or miss.Hydro Boost is the way to go.
  #24 (permalink)
Old 01-08-2012, 08:17 AM
LATECH's Avatar
Last journal entry: New Gas Tank
The electric booster has been used on 88 t birds that were turbo, GM had them for a few years as another person posted, and yes , they were very unreliable.
Ford has used them as a safety backup brake booster for the f 600 (and up) since back in the day.It had hydro boost w a electro boost piggybacked to it.pretty cool.
The turbo t bird ones were pretty reliable actually and were implemented with the ABS which you can simply not use if desired.
I would pesonally go for the hydro boost setup. They are very reliable .As they are pretty common, parts are readily available too.
It pays to shop around . someone has to be making these with chrome and better outwardly apearance for us hot rod guys.
  #25 (permalink)
Old 09-18-2012, 12:52 PM
Electric Brake Booster
This is the Electric brake booster, it is an obsolete Jeep electric brake that was made by Bendix, they are out of production, there are only cores available, and those cores are polished up and sold as new. Even the 'new' master cylinder castings have the internal parts from the used cores.
Cores are taken off a car because they have previously failed, or the car has been scrapped because it was worn out, 'Cores' are often rebuilt with new parts and sold as 'rebuilt'. This unit is obsolete and there are no new parts, only old parts from other cores - 'Used' not 'Rebuilt'. The electric motor, accumulator, and pressure switch are constantly failing on all vehicles with electric type brake boosters, and the owners of vehicles with them have to source and replace one of the three parts about once a year - so they are looking for ways to get rid of it and convert to something else. You are being charge $1,100 for a junkyard product.
  #26 (permalink)
Old 10-11-2012, 11:33 PM
ClassicDriver's Avatar
What about ABS's system?
What about the system from ABS Power Brake Inc?... Is this stuff considered bad?
The Best in Brakes & Steering...
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Brake booster M&M Suspension - Brakes - Steering 5 03-31-2006 01:56 PM
I need a remote power booster nprfan Suspension - Brakes - Steering 10 10-20-2005 02:08 PM
power brake booster vacuum canister?? Ed ke6bnl Suspension - Brakes - Steering 1 10-21-2004 04:33 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Looking for a deal on power Brake booster,with pedal&combo valve for willys Harry Hut Interior 0 04-02-2002 01:36 PM
