Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - electric power window crank switch
Old 01-10-2011, 06:35 PM
Hot Rod Mike Hot Rod Mike is offline
Hey guys,
I'm looking into the electric power window crank switch option that allows you to use your original manual window cranks. The window goes up/down by moving the crank handle approx. 15 degrees in either direction. I've done some searching & found 3 suppliers: Autoloc ($99 ea); Watson's & also Electric Life (both approx $ 130). I like the Electric Life units as they are covered w/Delrin which I would hope would provide some weather protection.
I have a 33 Ford 3W coupe (steel). Has anyone tried these power cranks in the past ? Any vendor(s) preferred over the others ? Are you happy w/this design ?
Thanks,
Mike.
