Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - electric power window crank switch
Old 01-11-2011, 08:46 PM
52Dodgeman 52Dodgeman is offline
window motors/switches
I have used two '90 model Toyota motors to electrify my windows on an old Dodge pickup. Cut the handles and original crank gears off your regulators, cut the motor and gear off the Toyota regulator and weld them in place on your regulators with the gears meshed and you're set. Three $24 switches from NAPA will complete the installation in your doors. Not as hidden as the 15-degree movement switches you mention in your question, but a whole lot less expensive.
