Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - electric power window crank switch
Old 01-28-2011, 12:34 PM
CarGuy350z CarGuy350z is offline
You're right on, EOD Guy. The problem is knowing which parts are good before you buy and find out the hard way. That's why I posted a reply here to begin with. Knowing WHO you are buying from is often more important than WHERE you are buying from.
Both of the foreign made kits that I referred to, by experience, are of questionable quality and are not backed up by their suppliers. (In fact, both of those kits are copies of the Carolina Custom kit which came first.) The other one is quality and is backed up by both the manufacturer and the seller that were listed. If you didn't check out that one link that I put up earlier, you might want to.
