electric "pulse " speedo question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2013, 06:20 PM
as u see by the pic, all parts on the left came off my old trans 350, and my new trans has a larger hole on the tail shaft. can I just swap tail shafts to make it work? If not is there a sleeve or something I can purchase so my old parts will work? If not what do I have to do so my electric speedo will work? Thanks again, Dana
Name:	2013-09-03 20.04.08.jpg
Old 09-03-2013, 06:59 PM
RWENUTS's Avatar
I don't have an answer but these guys will.
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
Old 09-03-2013, 09:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I guess you are working with a T-350 and a 700r4 trans?
The T-350 tail will not bolt on the 700r4 trans and function
You need 700r4 correct speed-O parts for the 700r4. T-350 parts do not directly swap over to 700r4.
700r4 parts:
; then thread on your pulse generator.
The 700r4 speed-O parts will need to be the same ratio as the speed-O parts from the T-350 trans.
The T-350 plastic drive gear (Chevy style) that fits the output shaft is not the correct diameter for the 700r4 trans
Old 09-04-2013, 07:21 AM
crosley, in other words if I order the parts (kit) for a 700R I should be fine? Is there a part #, and who would be the cheapest? Thanks again for all the help, Dana
Old 09-04-2013, 10:12 AM
I just answered my own questions, thanks till next time, Dana, but have to find out my stock rear end gear ratio, 1951 2R5 Stude pick-up.
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
electric fan led "ON" indicator springerspanielcars Electrical 10 04-06-2009 10:29 PM
"electric vacuum pump for the brake booster" Joe DA Suspension - Brakes - Steering 19 01-28-2009 09:13 AM
Electric cooling fans. "Pusher" or "Puller"? NASCAR314 Engine 4 11-09-2002 04:06 AM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
