-   -   Electric Pump with Performer Carb (http://www.hotrodders.com/forum/electric-pump-performer-carb-142125.html)
307malibu 07-16-2008 10:54 PM
I just got my '97 Silverado motor in the Chevelle and I'm ready to bolt on carb and accessories and go!!! Finally. Thanks for all the help up to this point. :)
Now, I'm going to have to run an electric pump since my block does not have a mechanical provision. I was thinking of using Carter's #P4070, which is a "street" pump rated at 72 gph with 5 psi, using 1/4" npt fittings. I would think this would work well with the 600 cfm edelbrock performer I'm using on this mild 350. A few questions, then:
1) Will this pump work well?
2) Do I need to use a regulator?
3) Can I just wire it in to a "keyed" slot on my fuse block?
4) Where is the best place to mount it and a good way to plumb the lines to the carb?
Thanks everyone! Almost there. . . .
sugar ray 07-16-2008 11:17 PM
im running a similar set-up with a small block chebby, however im using a holley street electric pump with a edelbrock 750 carb. so your pump and fittings are very similar to mine and i've had no issues!
i do NOT think you will absolutely need a regulator. Just the electric pump should be fine by itself, but maybe one of the great minds can correct me on that??
its a breeze to wire it up.It should only have 2 wires coming from the pump. one is for ground and the other is your power supply. you COULD wire it up to an IGNITION-on wire that way when your turn your key your pump goes on. I didn't do it that way. I chose to go with a toggle switch for it. Just a nice feature to be able to cut off your pump in case of an emergency at the 1/4 mile track.
As far as the lines, i just used good rubber fuel hose from the steel fuel line up to the carb. Again i assume you have steel fuel line that runs from your tank up to the front of the motor area?
Mounting is important. Remember, a fuel pump will PUSH better then it will PULL. Thats why most pumps are mounted in the tank or near the rear of the vehicle.
good luck
SSedan64 07-16-2008 11:42 PM
Mont the pump as close to the tank & low as possible. Also use a relay when wiring it up.
307malibu 07-17-2008 07:28 AM
Thanks for the advice, guys. Sounds pretty basic as long as I follow a few guidelines. Appreciate the help!
