Electric radiator fan question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2009, 06:46 PM
Last journal entry: test
I have a problem with hooking up my a/c on my 1929 ford model A tudor, the problem is that the electic fan motor is in the way of the belt... someone had mentioned to me that you can get a fan with the motor offset mounted on the top is this true and if so where could I find such a critter?
thanks,
simon
Old 02-08-2009, 04:10 AM
Joe G's Avatar
thanks,
simon
Simon,
The Fan Man sells a fan called the Sidewinder - I think that may be the critter you're referring to. It's 1 5/8" thick in the middle. I used one a few years ago on a '65 Ranchero. Worked perfectly. It wasn't cheap, but it got me out of a jam.
Here's a link to the Fan Man's products page. The Sidewinder is about halfway down the page.
http://www.the-fan-man.com/sidewinder.html
Hope this helps.
Joe G.
Old 02-08-2009, 06:17 AM
Joe G.
Thanks that is defiantley the critter I am looking for !
Old 02-09-2009, 08:33 PM
406 bug's Avatar
9.82 @ 139mph
Can you use an idler pulley to make clearance?
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Demon electric choke question dustychevelle Engine 4 10-20-2008 03:21 PM
electric fuel pump install question bet on black Engine 5 02-01-2005 05:32 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
