Electric Seat Hookup - HELP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2012, 04:47 PM
Axis_of_Evil's Avatar
Can't get seats to work????
I am getting ready to put a couple of front bucket seats from a 2007 Cadillac DTS into my '50 Ford. The controls are on the side of these seats.
I've attached a picture of the underside of the driver seat and the electric diagram that a friend printed off for me.
I have tried to use the RD/PK wire in the main connector (red arrow) as the positive, and the black wire in the main connector as the ground to a 12 volt battery with no luck (nothing happens).
I don't know much about electronics and don't want to BBQ the seat's controls..... any suggestions?
Thanks!
Axis
ID:	63891   Click image for larger version
Old 03-10-2012, 05:28 PM
Hoptup32's Avatar
I would suspect that if the black wire in the plug assembly is in fact the ground, it would be the same gauge wire size (large)as the RD/PK power wire.
Is it possible that the individual motors are grounded locally to the steel seat frame and the seat frame in turn is grounded to the vehicle frame when the seat is bolted in place?
Old 03-10-2012, 05:42 PM
Hoptup32,
Thanks for the quick reply!
There are 2 black wires in the plug assembly and one is larger (gauge) than the other. The larger black wire is the same gauge as the RD/PK wire.
I tried hooking both black wires to the negative side of the 12 volt battery when testing the seat switches... nothing happened in either case.
Also, I tried to ground the negative side of the 12 volt battery to the seat frame, thinking like you, that maybe the motors were grounded to the seat/vehicle frame... still nothing?
It's amazing how many wires, connections, etc are contained in the bottom of the seat... also parts from China, Phillipines, Canada and US.
I know this can't be that hard... just need to hook into a power source... hmmmm???
Thanks again!
Old 03-10-2012, 07:43 PM
Curious.......How many other wires, & what are their colors are in that connector? The two that you have identified are correct for the power, & ground connections, however, the others in the connector may need to be addressed as they may be part of the Cadillac inter-loc system.
Give us the wire color markings, plus, with your VOM, check to see if any of them (the other wires), have continuity to ground.
Old 03-10-2012, 08:28 PM
I forgot to ask; does the passenger seat operate with just the power, & ground wire connected? If yes, the issue for the driver's seat may be due to the memory seat function in the factory configuration. The connector info (& the differences in the passenger seat connector) will help us figure out the needed wiring.
Old 03-10-2012, 08:51 PM
Crdnblu,
Thanks for the help!!
I only have the driver's seat at the house at the moment (I'm working on the car in my garage)... the passenger seat is in storage facility.
I assume both of these seats are working, they were just removed from a wrecked Cadillac. I bought them after they were removed, so I did not get to see them work. Both seats are in great shape.
This is my first attempt to see if they (the driver's seat) work.
As for the other wires in the main connector of the driver's seat... there are approx 40... all colors of the rainbow, and then some.
I found my multimeter (which I've never really known how to use), had to borrow a 9v battery from another device (battery was dead in the multimeter).
I started testing for continuity with the black (ground pin) wire in the main connector. After testing 4 or 5 wires, I found 1 that had continuity... it was a grey wire. So, what does this mean? (I haven't tested the other 35 or so wires yet).
p.s. there seems to be a lot more wires in the seat than on the wiring diagram my friend gave me?
Thanks!
Old 03-10-2012, 10:47 PM
Yep, you're going to NEED some help on this one. First, I would visit your nearest friendly Cadillac parts dealer to obtain copies of a 2007 wiring diagram for your seat(s). [driver's, & passenger diagrams are different]! You may have to pay $, but it will be worth it in the long run. If no help there, join a Cadillac owners forum, & see what you can obtain as far as wiring diagrams.
Secondly, I would START with the passenger seat; they are MUCH easier to figure out (with/without a wiring diagram). From the size/number of wires in that driver's seat connector, Cadillac might have gone to one (1) connector for all the seat functions (memory, heat, etc.), where they used to have multiple connectors. The '94 Eldorado seats that I have use multiple connectors. The passenger seat was straight-forward; the driver's seat required some jumper connectors to by-pass the memory module.........
Old 03-10-2012, 11:02 PM
Take a look @ the attached PDF file of the 2007 Owner's Manual; you'll see the added controls that are NOT on the seat(s), but on the door panel, controlled by being in "park", etc. That's why there are SO MANY wires in that driver's seat connector, going back to the body/chassis, where the switches/controls reside:
http://www.cadillac.com/content/dam/...dts_owners.pdf
VERY hard to trace w/o a wiring/color-code diagram.....
Old 03-10-2012, 11:39 PM
Crdnblu,
Again, thanks for the info and owner's manual!
I finished checking continuity on the large connector on the driver seat (the only other connector is the small yellow connector for the seat airbag), and found only one wire TN/RD that has continuity (I was incorrect in my earlier response about the grey wire).
I'll try to retrieve and check the passenger seat tomorrow (assuming not too much rain here). Hopefully it will be simpler and will work with just power and ground wires attached to a battery.
In any event, I will also try to get the detailed wiring diagram from a Cadillac dealership. Assuming I'm able to get a detailed wiring diagram, then what would be the basic game plan (you had mentioned jumpering some wires to bypass driver side memory)?
I just need to get the basic seat movements/motors to work on the driver's seat? I'm not interested in the heat or massaging Lumbar capabilities (mine does have these but not the seat cooling/ac feature).
Suggestions?
Thanks!
Rob
Old 03-11-2012, 08:35 AM
If you don't already have a set of alligator-tip jumpers, make a trip to your local Radio Shack, (or equivalent), & pick up a set; they'll come in handy for MANY projects.
After reviewing your procured wiring diagram(s), (**Don't forget to look for ANY DIAGRAMS that will show EXTERNAL switches/interlocks that control your seats**), you'll want to identify & trace ANY modules/wiring under the seats that ultimately go to that main wiring connector, & out to the car body to be controlled by other than the seat buttons.
[The main culprit, that usually needs to be "jumpered", is the seat memory module; usually requiring a connector ("jumper") across the leads to make the module see a closed circuit, allowing the seat to operate properly.]
Another point: You may not need/want the massaging lumbar feature, but you'll need to address it, as it MAY be tied into the lumbar support circuit, which you WILL need to comfortably fit your seat to your frame. There is NOTHING worse than a lumbar support that is too high/low, or pushes into your back-side, impairing your comfort.
Old 03-11-2012, 08:59 AM
Take a look @ this link:
http://www.justanswer.com/cadillac/5...ont-seats.html
Old 03-11-2012, 09:55 AM
T-bucket23's Avatar
Wiki Edits: 26
It looks like, from my schematic, you will need to power up more than just the pink/red wire. You will need to get power to pink/red, the tan/yellow, and the orange/brown wires in order for the seats to work on the drivers seat. The passengers side should only require the one hot and ground to work.
Chet
Old 03-11-2012, 10:10 AM
Crdnblu & Tbucket,
Thanks again for the great information and link to JustAnswer.com!!
I'm heading out to get the passenger's seat out of storage. I'll try these new recommendations for both the driver and passenger seats.
I'll report back later today.
You guys are awsome!
Regards,
Rob
Old 03-11-2012, 02:43 PM
SUCCESS!!
Here are the results;
- DRIVER SEAT WIRING:
"+" Red/Pink, Tan/Yellow, Orange/Brown
"-" Black (the larger one)
All seat movements work (front 2 switches)
The lumbar adjustment works (round switch)
The Lumbar massaging does not work (in the manual that Crdnbu supplied, it does say that the ignition has to be on for this to work... so, maybe that's at the heart of this issue.)
- PASSENGER SEAT WIRING:
"+" Tan/Blue (fyi... there is not a Red/Pink wire for this seat)
"-" Black
The lumbar adjustment does not work (round switch)
So, I have what I need and if I want/need to get the few remaining functions to work, I'll try to the same Cadillac mechanic in the JustAnswer.com link (thanks again to Crdnbu!).
Hopefully someone else can benefit from this information/experience.
Thanks and best of luck with your projects!
Rob
Old 03-11-2012, 03:01 PM
T-bucket23's Avatar
Wiki Edits: 26
Thanks for letting us know.
Glad to have helped
Chet
Gear in this thread - Powered by O'Reilly Auto Parts
Bench Seat Swap To Bucket Seat Help arnellwest Hotrodding Basics 11 03-28-2011 10:50 PM
electric brake hookup yragat Electrical 8 06-30-2007 07:34 AM
Electric seat parts trucksbyjim Interior 12 05-03-2004 08:47 AM
Camaro Electric Fan Hookup? Jag Daddy Engine 9 03-07-2004 02:32 PM
Electric Seat motors Retrofit. WardellW Interior 4 10-18-2002 12:43 AM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
