electric speed sensor wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2010, 05:30 PM
I switched from a 350 turbo with a mechanical speedo to a 700r4 with a electric speedo. I have a Autometer electric speedo. Just wanting to know how to tell which wire will be grd.,and of course which will be the sender. If it helps,the speed sensor is a Napa #LS6533,containing a black,and a purple wire. Thanks for any response.
Old 09-15-2010, 06:00 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
The speedometer sender must be matched to the speedometer. If that is not what you have anything else is a guess.
vicrod
Old 09-15-2010, 08:28 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
If your speedo is just counting pulses----does not really matter.
but, the black wire is probably the return.
I would assume that the speedometer is getting 12v with the key on by a wire fed by the fusebox, and 2 different wires going to sending unit??
FYI----twist the wires going to the sending unit and keep them far away from the spark plug wires, distributor, and tach signal wire.
If the speedo wires get to close to any of these---you may register speed without moving.
Old 09-15-2010, 08:56 PM
Thanks for responding,and yes Bryan you are correct. Yes it is counting pulses. The speedo is setup like you described for a mechanical speedo. According to Autometer instructions,it will also work with a 2 wire sine wave sender. That shows 1 wire from the speed sensor going to the sender on speedo,and the other wire from the speed sensor being a ground. Again Thanks for any response.
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 07:44 AM
4 speed VS. 5 speed trans burtondemo Transmission - Rearend 4 08-18-2009 09:24 PM
95 Mustang 2 speed electric fan & 351? macx Engine 3 09-01-2007 01:13 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Th350 to 4 speed auto conversion Bandit1980 Transmission - Rearend 3 12-29-2004 07:41 PM
