-   -   electric speedo to mechanical speedo? (http://www.hotrodders.com/forum/electric-speedo-mechanical-speedo-227717.html)
31ROC 12-29-2012 07:49 PM
OK guys...I am removing a 700R4 A/T amd replacing with Muncie 4 speed M20.
The 700R4 had electrical wires running the speedo, this Muncie needs a speedo cable...is there a conversion kit out there? Or do I need to change the speedometer?
thanks!
Bryan59EC 12-29-2012 08:54 PM
If you have teh ability to calibrate your speedometer, you might give Dakota Digital a call.
They may be able to supply you with a pulse generator that fits in the speedometer hole of the trans.
I have one of these in my 59 with a TKO----but I do have the Dakota Digital gages as well.
I see no reason why the pulse generator would not work on your speedo-----if you can calibrate it.
31ROC 12-30-2012 04:17 AM
Thanks Bryan.....thought I was gonna have to change the speedo....
31ROC 12-30-2012 05:21 AM
I think I found the answer.....
Auto Meter
Bryan59EC 12-30-2012 10:04 AM
A much prettier version of the one Dakota supplied me with.
