electric speedo to mechanical speedo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2012, 06:49 PM
31ROC's Avatar
OK guys...I am removing a 700R4 A/T amd replacing with Muncie 4 speed M20.
The 700R4 had electrical wires running the speedo, this Muncie needs a speedo cable...is there a conversion kit out there? Or do I need to change the speedometer?
thanks!
Old 12-29-2012, 07:54 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
If you have teh ability to calibrate your speedometer, you might give Dakota Digital a call.
They may be able to supply you with a pulse generator that fits in the speedometer hole of the trans.
I have one of these in my 59 with a TKO----but I do have the Dakota Digital gages as well.
I see no reason why the pulse generator would not work on your speedo-----if you can calibrate it.
Old 12-30-2012, 03:17 AM
31ROC's Avatar
Thanks Bryan.....thought I was gonna have to change the speedo....
Old 12-30-2012, 04:21 AM
31ROC's Avatar
I think I found the answer.....
Auto Meter
Old 12-30-2012, 09:04 AM
Bryan59EC's Avatar
A much prettier version of the one Dakota supplied me with.
Mechanical speedo conversion on 200r4? 283sn187 Transmission - Rearend 8 08-01-2012 02:17 PM
Convert speedo to Electric charlesmajor Transmission - Rearend 4 03-20-2012 11:54 AM
mechanical speedo for electronic trans wallya Transmission - Rearend 6 03-16-2012 07:48 AM
TPI Electric speedo?? Bluepen Electrical 3 01-23-2009 09:55 AM
Mech to electric speedo alf1096 Engine 1 07-25-2005 06:36 AM
