Electric trailer brake axle mounting - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2009, 05:32 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I needed different axles for my car trailer (the electric brake parts are no longer available for the existing one-- and I needed both axles to have brakes per state law....). I bought two used axles with electric brakes, but I ran into a snag. The existing axles are mounted above the the springs, but my "new" axles have the spring perches welded on for a "below the spring" application. That is, if I leave the brake stuff mounted the same on the axle. I "think" I can re-mount the mounts, but I'd rather just "flip" the brakes so the actuator is 180 degrees off my existing setup. Can this be done? Better yet, should this be done? Thanks,
In a while, Chet.
Old 04-08-2009, 06:35 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm not sure if this is what you're after, so bear w/me.
If I'm following you, if you flip the new axle to get the perches on the top like the original axle, you would then swap ends to keep the leading/trailing shoes in the correct positions.
Then, invert the springs so the arch is correct, or use your original springs.
Old 04-08-2009, 06:41 PM
schnitz's Avatar
Wiki Edits: 54
You've got it, but will the actuator work right if I do this? Or should I just remove the axle spring perches from the axle, and then re-weld them on 180 off of what they currently are?
In a while, Chet.
Old 04-08-2009, 06:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The only forces that will be at work that would change how the brake mechanism works if 180* from original is gravity, IMHO.
I think that- provided the brakes are in good condition (no rusty springs, etc.)- there should be no difference as to how the brakes work.
At least I can't come up with a reason that having the actuators 180* from original should affect the function of the brakes- as long as the orientation of the leading/following shoes is preserved.
Old 04-08-2009, 07:01 PM
schnitz's Avatar
Wiki Edits: 54
Guess I'll be figuring it out soon (like right after I get the spring eyelet bolts to free up...). Thanks for the advice/thoughts on it!
In a while, Chet.
Old 04-08-2009, 07:06 PM
Joe G's Avatar
Registered user
Originally Posted by schnitz
....Or should I just remove the axle spring perches from the axle, and then re-weld them on 180 off of what they currently are?.
That may be a safer bet.
Most (maybe all) trailer axles have a slight upward arch built into them. It is done so the axle will flatten out at it's rated load instead of sagging.
If you were to flip the axle, that arch would be working against you - giving you built in axle sag.
If it were me, I would weld some new spring perches on the bottom of the axles. You might not even have to remove the top perches if you don't want to.
Good luck
Joe G.
Old 04-08-2009, 07:13 PM
schnitz's Avatar
Wiki Edits: 54
Crap. I forgot all about that, Joe. Maybe I will just weld new ones on.
In a while, Chet.
Old 04-08-2009, 09:15 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
In a while, Chet.
heh heh heh
no point in cutting and welding---if you can just weld.
Don't flip the axles for the reasons stated above.
Old 04-08-2009, 09:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yeah, do what they said.
Old 04-08-2009, 10:57 PM
prostreet6t9's Avatar
Differential/Driveline
The arch is kinda dual purpose,Its there for the load support, and also to set the toe. Just get another set of perch's and install them with the bow going up.Before you weld the perch's make sure and check your toe so you don't scrub the tires.
One thing to think about also is, since your state requires brakes on both axle's,it's not uncommon to have the the state police check your brake set up,and have you prove your breakaway setup is working,if they notice your brakes are on backwards he will nail you pretty good.
Dont invert your spring's. Just weld new perch's on.
Old 04-09-2009, 08:28 AM
I assume it's not possible to simply unbolt the brake backing plates and flip them around?
Old 04-09-2009, 09:57 AM
Yes,you can do that on most axle's. I have seen some that actually have the backing plate welded on.
There is a right and left brake assembly, so when it's done,the magnet is at the bottom with the adjuster,short shoe to the front and the wire needs to exit to the rear. If a state police wanted to be a butthead and noticed that the wires where coming out the front of the backing plate he would know they where on backwards and possibly give you a hard time.
Idiot Proofing My Trailer Wires Rob Keller Electrical 41 05-14-2007 07:32 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
