electric trailer brake wiring at the axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2008, 09:54 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I just inherited a trailer that had the electric (drum) brakes disconnected. Its a dual axle trailer with brakes on both axles. Everything is wired, except the connection to the brakes themselves. The backing plates have two posts each, and some 8-guage wires going across the axles to the other side, then my 8-guage wire coming in from the connector
I know it has to go through the magnets, but there is no indication on the axles which is positive and which is negative. All I have are 8 lugs connected to each other with four wires.
Like this quick pic I drew:
The brown are the axles, and the wires are the colored lines. (not actual colors, just drawn that way for contrast) The black line is my brake power coming from the connector. The wires on the actual axles are brown, blue, black, and orange with a green stripe... so I think they can't be used as clues
Old 07-17-2008, 04:38 AM
Last journal entry: T'Bird projectr
It doesn't matter, the magnet doesn't care whether it's + or -, as long as current flows. Just wire 'em up, pick one to go to the brake pin in the plug, go to ground with the other. I've wired several vintage travel trailer brakes, both original and new axles under 'em, they'll work with 6 or 12v, + or - ground, no problems.
Oh, I'd wire them so all the magnets are wired the same way. Pick which post on each drum for your + (hot) wire, and just pull the wire from the forward drum (by that I mean the one the brake lead goes to, usually it'd be the left front)to the other three. 8 ga. is huge, I bought a new Dexter 7500lb axle for our last Spartan, which was wired with 14ga from the factory. I used 12ga to the plug, worked fine. This must be a really old trailer?
Old 07-17-2008, 06:13 AM
Marcel
Last journal entry: Choo-choo town
wiring an axle
I'd use a meter to ensure which termial is ground. jmtc
Old 07-17-2008, 10:47 AM
curtis73's Avatar
Wiki Edits: 16
Actually its only 4 years old, but it has two 7000# axles and was homemade, so I guess the fabricator wanted to go overkill. I went with 8 ga because this is being towed behind a 24' box truck, so there is the potential for a 50' run of wire. I found 8 ga wire for 34 cents a foot and figured it can't hurt
Ok, so I'll just split my brake wire and go to the (let's say) front post on each brake of the one side. Then the existing wires on the axle will take voltage across. Same for the ground post; two wires from the rear posts to the frame. Sound good?
04 silverado trailer brake problem shady4 Electrical 2 05-17-2008 08:57 AM
Idiot Proofing My Trailer Wires Rob Keller Electrical 41 05-14-2007 07:32 AM
wiring diagram for brake light/indicator? pcoghlan Electrical 2 06-06-2006 02:58 PM
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 08:34 AM
2000 nissan trailer wiring Dawger Electrical 3 08-15-2003 08:07 PM
