Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - electric winch
Thread: electric winch
Old 09-06-2006, 11:56 PM
JADYNCC JADYNCC is offline
If it is a single phase 110-115VAC 4 wire motor, to switch directions is very simple.
Open the j box on the motor for(CLOCKWISE) put your 115 hot(BLACK) together with T1,T3,T8, then your neutral(WHITE) together with T2,T4,T5, this will give you a clockwise or forward rotation. Then to get counter clockwise simply swap T5 and T8.
SIMPLIFIED=
Clockwise-
>>>>hot(Black wire),T1,T3,T8-----------------neutral(White wire),T2,T4,T5
Counter clockwise-
>>>>>hot(Black wire), T1,T3,T5----------------neutral(White wire),T2,T4,T8
I hope this helps you, if I can help further let me know. Jadyncc
