-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Electric window motor replacement (http://www.hotrodders.com/forum/electric-window-motor-replacement-153520.html)
Bubblehead 02-16-2009 03:32 PM
I am getting ready to replace the motor on the passenger side, rear window on my 84 Ford Mustang. Getting to it is the question. After I remove the rear seats, does that side panel that covers the top mechanism come out? Is there a special trick to getting the seats out? Any advice or suggestions on this evolution?
Joe G 02-16-2009 05:27 PM
I would check a repair manual to be sure, but I believe the rear seat comes out like most cars. Lift the front edge of the seat to pop it out of it's retainer clips, then remove it. The seat back should be held in by a couple screws along the bottom edge. Remove them then lift the seat back out.
Once the rear seat is out, you should be able to remove the side trim panel to access the window mechanism.
Be careful with the window mechanism. It is spring loaded. If you remove the motor without immobilizing the arm, the arm can whip around hard enough to break any hands or fingers it slams into. :eek:
Good luck, and be careful :thumbup:
Joe G.
Bubblehead 02-17-2009 11:19 AM
Thanx, Joe G. I'll give it a shot and I'll watch my fingers....... :D
