electric window switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2006, 01:51 PM
GoneNova/406's Avatar
my daughter has a 93' pontiac sunbird that need a new switch for the drivers window.the problem is that GM and the parts stores don;t sell them anymore.does anybody know of some place that sells n.o.s. parts of that sort?only other option is to check each boneyard as i come to them.
Old 03-02-2006, 03:58 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Try Auto zombie , Kragen or parts America (even a Mom and Pop may have them) On The "HELP" tree.. they have replacement switches for GM, but:
Be prepared for sticker shock, they run between $29 and $79 bucks..
Doc
Old 03-02-2006, 06:08 PM
302 Z28's Avatar
If you know the part number you can go online to GM Parts Direct and see if they still have it in stock. Sometimes the dealer will quit carrying it but it is still availiable.
www.gmpartsdirect.com
Vince
Old 03-03-2006, 02:43 PM
thanks for your replies guys but i wouldn't be talking to you guys if i hadn't been to all those place's and checked with them first.if it had been a 91' i would have been ok.cavalier used the same switch.as it is though i have to either go to the junk yard and locate a convertable or 4 door 93 sunbird unless i can come up with the right search words and locate some n.o.s. parts.i'm hoping some of you guys happen to know the name of somebuisness that has (new old stock),or i may be screwed.
Old 03-03-2006, 03:02 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
If you can't find an exact replacement you can use an aftermarket switch from www.action-electronics.com Cat # GC-35-3560.
It's a DPDT (double pole, double throw, monentary) designed for the purpose of reversing 12 volt DC motors.
vicrod
Old 03-03-2006, 03:17 PM
thanks,i'll give that a try.
Old 03-03-2006, 03:28 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Try here :
Pontiac Sunbird Switch kits
The list Sunbird Switch kits , although I couldn't find them specfic..you might drop them an email..
Doc
Old 03-03-2006, 03:54 PM
thanks very much.it looks promising and i'll give it a try.
electric rear window defrost bracketeer Electrical 3 01-04-2005 07:20 PM
tilt front end -reverse polarity electric switch??? ActionPaintball Body - Exterior 6 11-14-2004 11:31 PM
DIY Shiftlight/ RPM Switch/ RPM Window Switch Junorr Electrical 2 09-07-2004 07:18 PM
Electric fan switch Loup Engine 1 03-29-2004 07:21 AM
Window switch removal Sundance33 Electrical 0 12-18-2002 06:53 AM
