Electric window switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2006, 03:59 PM
Last journal entry: 1949 Chevy PU 3/4t barn find
I have a 2 window switch I would like to install in the console. The switch has 2 flat buttons, 1 for each window that move up and down. On the back there are 6 pins. 1 of the pins is longer than the other. I have played with this with an ohm meter for several hours trying to figure it out. Help with a diagram please.
Old 06-05-2006, 05:34 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Typical GM power window schematic..
Doc
Old 06-05-2006, 05:48 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The attached sketch should help.
Just remember to reverse a DC motor the polarity is reversed.
The switch will have a common + and - feed connection points. (2) terminals.
It will have a right window switch position up +- and down -+ (2) terminals.
And it will have left window switch position up +- and down -+ (2) terminals.
vicod
electric window switch GoneNova/406 Electrical 7 03-03-2006 03:54 PM
tilt front end -reverse polarity electric switch??? ActionPaintball Body - Exterior 6 11-14-2004 11:31 PM
DIY Shiftlight/ RPM Switch/ RPM Window Switch Junorr Electrical 2 09-07-2004 07:18 PM
Electric fan switch Loup Engine 1 03-29-2004 07:21 AM
Window switch removal Sundance33 Electrical 0 12-18-2002 06:53 AM
