Electrical - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2008, 11:17 PM
Electrical
I have a 1993 Chevy truck that has a reaccuring problem of the bottom bulb burning so hot in the tailight that it is melting the plastic. I have heard of other people having this problem with similar make and models. Anyone know what is causing it & what I must do to fix it? Tired of having to replace it. It's becoming redundant. Any suggestions are more than welcome. Thanks.
Old 11-19-2008, 03:07 PM
Shelby1's Avatar
Steel Dreams
I had one that came in to the dealer that I worked for and I if I remember correctly I found that both elements in the bulb (brake and running lights) were on all the time that the lights were on .Traced it back to bad wiring done on trailer wiring.
Kenny
Lost your job yet?
Keep buying foreign.
Old 11-19-2008, 04:32 PM
302 Z28's Avatar
You might also check and see if you have a bad bulb. Sometime when a dual filament bulb burns out the filament will cross over to the other filament and both filaments will then burn.
Vince
Old 11-19-2008, 11:04 PM
bullheimer's Avatar
NEVER use credit cards!
lemme know when you figure it out, my license plate bulb blows my fuse after about a minute.
How to submit a post in the Electrical Forum docvette Electrical 0 06-02-2006 08:42 AM
*glossary Of Basic Electrical Terms* docvette Electrical 2 04-28-2006 07:27 PM
How To Submit A Post In Electrical Forum docvette Electrical 0 04-25-2006 05:46 PM
Hotrodders Knowledge Base: Electrical Jon Electrical 0 11-26-2005 06:41 PM
