Electrical Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2005, 05:04 PM
Electrical Block
Hey Guys I have all my wiring under my seat in my street rod.With all the connections it looks like a rats nest. I wanted to know if you can use a electrical block/thermial block for my power suppy.I would have one power scorse going in and feed power to other things.I know you can use blocks for grounding things,but for power supply i am not sure.
Old 06-12-2005, 06:14 PM
302 Z28's Avatar
You need to feed all circuits from a fuse block. If you are trying to use the original wiring I would abandon that idea and purchase a good quality wiring kit. They are not that expensive and make a rewiring job a breeze.
Vince
Old 06-12-2005, 07:55 PM
docvette's Avatar
Wiki Edits: 12
Wiring
Doc here,
After you remove ALL the old wires, Start at the solenoid main bolt, There , Install a proper fusible link trident, Run that wire From there to The Fuse block, and Switched Ignition Buss, and a third to the alternator power.
Decide whether or not your fuse buss will be switched, (key on/ Acc ) or unswitched, or split buss (both 1/2 switched, 1/2 unswitched)
If it's to be all switched, wire it direct from the Ignition switch.
If it's to be split buss, Isolate both sides, and wire one to your fusible link, the other to your switch On/Acc...
If you have HIGH current draw devices, like an electric cooling fan, or want safer, brighter headlights, you must use Relays..to control the power from your battery fuse link to the draw, and the switched , fused side to control the relay coil.
You Can use a standard (properly gauged ) terminal block, BUT you need fuse / Fusible link protection...A Terminal setup won't prevent fires in case of shorts...
As suggested, you can get an AZ or Painless kit for around $200..and start from scratch, OR you can get just a fuseblock and wire from there..you can get one here:
http://www.painlessperformance.com/w...-fuseblock.htm
Or you might just try the local bone yard for one that suits your needs.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
i'm looking for a better 400 s chevy block 406 ss monte Engine 3 08-23-2005 07:48 PM
i need a better 400 sbc block 406 ss monte Engine 5 06-21-2004 11:31 AM
Big Block/Small Block - Ford BigBlockBabe Engine 12 11-10-2002 04:01 PM
Block Painting do's and dont's Maverick Engine 20 11-02-2002 08:50 AM
