Electrical, Charging System
Please, can anyone assist me in my search? I am building a 1932 Ford Highboy with a 'modified' 1948 Flathead V8. I am going to go with a rebuilt generator converted from 6 to 12 volt. My question is: How do I select and find the correct voltage regulator? Are there other concerns and items that I should be aware of to complete a successful Charging System?
I have spent hours searching the Forum history and data bases with no luck. |
Electrical system
Built a 32 p/u with a 48 Flathead, used the innards from a later Ford 12 volt generator,(junkyard stuff) and a regulator from a late 50's Ford.Mounted it on the frame under the right floorboard, left the starter at 6 volts,never had a problem.
Doc here,
You may want to also consider an Electronic Solid state Regulator in place of the mechanical (Later Model Ford) , You'd just need to graft a plug to the existing harness. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Thanks for the most welcomed feedback, Guys. But, it doesn't quite answer my question. In my search for a regulator I discovered hundreds of different types, makes and sizes. How do I choose the correct one?
Don: You used a late 50's Ford regulator. Do you know what Brand and Model #? Doc: You made it a little more confusing for me. I'm an old guy with old methods that thinks and moves slower than you younger builders. Can you suggest regulator brands & models that I can search for? I do not have my wiring harness as yet, that comes next in the build. What is the grafted plug all about? Thanks again, Guys. Lee |
Doc here,
The Regulator I am talking about is solid state, was used on later model Ford Type Vehicles , and Looks like a "Thin Heatsink" that bolts on the Fenderwell..it has a Semi Round "D" Type weatherproof Connector, and I think (but Don't quote me on this..) It's "Generic Counterpart" is VR~75. Since you will be using a new harness, no grafting is needed, you can just install a NEW plug and pins on the new harness to mate the regulator as per your Harness Schematic. Doc
| Ignition system info................ | poncho62 | Electrical | 18 | 10-11-2008 10:10 PM |
| Charging system info............... | poncho62 | Electrical | 11 | 11-26-2005 08:53 PM |
| GM truck charging system ? | outlaw17 | Electrical | 2 | 06-03-2005 03:55 PM |
| Battery problem? | evltwin | Electrical | 11 | 04-10-2005 06:45 PM |
| Should I keep my hydro-boost brake system? | drlindz | Suspension - Brakes - Steering | 3 | 09-11-2003 09:38 PM |
