Electrical Device? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2007, 12:22 PM
S10xGN's Avatar
Gotta love a turbo!
Electrical Device?
Hi All,
Ya'll have about got me talked into upgrading my PVC air lines. When I do, I want to move my compressor to my back garage (out of earshot) about 60 feet farther out from the house. I'm concerned that it may burn up if something happens and I can't hear it (although chances are much slimmer with metal piping vs PVC).
I'm looking for a breaker or switch that can permanently remove power (trip) after it's attached device (compressor) pulls power for 10 minutes or so without cycling, then requires a manual reset. This could prevent the compressor from overheating and possibly causing a fire. Probably overkill, but since I'm redoing things anyway...
Russ
Old 02-21-2007, 03:18 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Not sure what Compressor you have, or power to it, But you may want to see if a Motor starter relay with heaters and thermal overloads can be used for this purpose, It would open a heater (opening a leg) or thermal overload, if the motor was drawing too much current, thus shutting it down.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 02-22-2007, 12:13 PM
S10xGN's Avatar
Gotta love a turbo!
Doc,
This (if it exists) would be more like a timer than an overload. My compressor is a 7.5 HP 220V that draws around 30A at full load...
Russ
Old 02-22-2007, 08:03 PM
docvette's Avatar
Wiki Edits: 12
Doc Here,
Here is what you want:
Motor overload and starter
Doc
Innovations
Old 02-23-2007, 08:30 AM
Originally Posted by docvette
Doc Here,
Doc
That will work but the only thing you must be aware is that it has to be a double pole to break both leads for 240V. For 120 volt you only need single pole. His compressor motor should have built in over load protection anyway if it's single phase.
Old 02-23-2007, 12:37 PM
S10xGN's Avatar
Gotta love a turbo!
I'm not convinced that's what I need. I don't think my compressor will ever "overload" electrically, but I can imagine it running continuously (I.E. broken airline) and getting hot enough to catch fire. Being out of hearing range, that would be a concern.
Russ
Old 02-23-2007, 01:07 PM
Russ
You could install a "run" light in your garage that comes on when the motor runs.
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
How to submit a post in the Electrical Forum docvette Electrical 0 06-02-2006 08:42 AM
*glossary Of Basic Electrical Terms* docvette Electrical 2 04-28-2006 07:27 PM
How To Submit A Post In Electrical Forum docvette Electrical 0 04-25-2006 05:46 PM
Hotrodders Knowledge Base: Electrical Jon Electrical 0 11-26-2005 06:41 PM
