Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electrical disconnect
Old 07-05-2012, 06:06 PM
krruzer krruzer is offline
Sure , I have a painless model 30204 electrical disconnect now wired into my car. It has a constant draw when energized even with the key in off position. I need to remember to always turn off or in a day or two you have dead battery. Running a optima red top and if you have ever had one dead it's a real project to get it to take a charge. I want to switch to a different type of solenoid that uses a momentary on, no power draw when on and a momentary off also no power draw. I've found the accompaning solenoid that are used by RV owners to keep there batterys from going dead when in storage. My concern is the wiring detail to install Thanks for your reply.
