Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electrical disconnect
Old 07-21-2012, 10:04 AM
krruzer krruzer is offline
follow up
Many times I follow a thread to find out how a problem is ultimately solved but, it ends with no real solution. My electrical disconnect question gave me some great advice.1st of all I was looking at the wrong solenoid to use for my particular application The orginal intellitec solenoid would have worked with some additional wiring for the switch. The suggestion to look at the Cole Hersee model #24200 was the answer. I did have to find the momentary switch which turned out to be a Carling technologies part #6fA54-73XG. I found it at Granger there part #4X200. It is a spring back momentary toggle SPST. So in wrapping it up, I want to thank all for the great feed back and direction.
