Electrical Fan Connection
I'm converting over from a mechanical fan to an electric SPAL fan and will
be installing a simple "on/off" switch.
There are only 2 wires involved (red/hot and blk/ground) and the on-off switch.
If I run the hot wire back to the fuse box at the "ignition" connector, will I need to install a fuse between the on/off switch and the fuse box? Or will the ignition connection provide the required protection?
Can I ground anywhere, or should I ground at the on-off switch?
Make: Chevrolet
Model: Impala
System: 12V
Engine: 327 cui
Year: 64
