Electrical grouding issue? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2010, 07:18 PM
i just got done pulling out the 300 I6 that was in my 88 f150 and throwing in a carburated 351w. i went to see if it would turn over and it didnt move. it sounds like the starter is engaging the flying ok but it wont budge the engine at all. i know the engine isnt sized as i spun it with a pry bar on one of the alighment pins when i had it out. my question to you guys is do you think i might just have a bad starter or do you think its a better chance that i just dont have the engine and chassis all grounds proporly attached (as i didnt take all that much time to attach the wires great).
Old 10-09-2010, 09:59 PM
mud.man.rj's Avatar
to tight
First off get under and see if you can turn the flywheel/flexplate with a pair of vise grips, if it is an auto maybe the torque converter wasn't back all the way and isn't fully into the pump, real common prob.
Old 10-10-2010, 05:40 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
If the starter is engaging that sort of says you gota ground, pull the plugs and see if you can turn it, mud.man.rj makes a good suggestion .
Old 10-10-2010, 11:55 AM
yeah ill give that a shot and see what i can come up with thanks for the suggestions guys
Heater switch issue..? el pollo Electrical 3 11-02-2008 07:13 PM
*glossary Of Basic Electrical Terms* docvette Electrical 2 04-28-2006 07:27 PM
How To Submit A Post In Electrical Forum docvette Electrical 0 04-25-2006 05:46 PM
Hotrodders Knowledge Base: Electrical Jon Electrical 0 11-26-2005 06:41 PM
Electrical Advice willowbilly3 Electrical 25 12-26-2004 10:11 AM
