Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electrical help, please
Old 09-28-2012, 03:45 AM
EOD Guy's Avatar
EOD Guy EOD Guy is online now
If you are using the ford sol to cut off pwr from the battery etc.... I'd hook the ing wire from the new wiring harness to the batt terminal on the dizzy and not use the "I" terminal on the ford sol. If you run it thru the "I" terminal..... just one more problem area that you don't need.
But yes it will work.
