Electrical help, please
I am wiring my '39 Ford tudor with a Gearhead Enterprises wiring harness. I am using a Ford solenoid with a trunk mounted battery. The diagrams I have seen say to run the "I" terminal of the solenoid to the coil and the "S" terminal to the ignition switch. I'm running an HEI distributor. Do I plug the wire from the "I" terminal into the distributor cap power wire plug in? Also, I plan to run the alternator output wire to the battery wire on the Chevy solenoid and I already attached the solenoid wire from the fuse box. Am I on the right track? Thanks in advance, Rod
The "I" terminal and wiring is not used on the HEI dist.
The Ford solenoid is not needed. Just something else to fail. The Ford solenoid will shut off battery power to the starter. The alternator will need to be routed to the fuse block. vicrod |
thanks EOD guy & vicrod
Hey guys, thanks for the replies. I'm now making progress. Thanks again, Rod
| help with electrical | Smokeytires | Engine | 1 | 10-30-2009 08:49 PM |
| electrical | craig2012 | Introduce Yourself | 2 | 09-20-2007 04:36 PM |
| Electrical | w777 | Electrical | 1 | 09-09-2007 06:51 AM |
| electrical help | japglass | Electrical | 1 | 10-30-2005 01:56 AM |
| Electrical | knumbskull | Electrical | 5 | 08-11-2003 05:31 PM |
