electrical junction block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2012, 10:44 PM
I'm about to wire my '39 Ford two door sedan. Should I come off the alternator, (3 wire)through a junction block to the solenoid, and from the junction block through the firewall to the fuseblock , or just connect them together and go through the firewall from the solenoid? Maybe it doesn't make any difference. Thanks in advance, Rod
Old 07-26-2012, 11:12 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Mad Electrical has an article that you may find helpful.
(Warning: It's a long read.)
Old 07-27-2012, 04:48 AM
EOD Guy's Avatar
This is how I wired mine
Old 07-27-2012, 05:27 AM
Electrically it doesn't matter, as long as the wire sizes are large enough and you have good connections. However, using a junction is very convenient.
Chevy trucks from the early ninties use a junction strip (five posts?) mounted on the firewall above the passenger side valve cover, and it is very easy to find all the power connections. The alternator charge wire runs back to the junction, and a power wire runs up from the solenoid to the junction. Then there are three other posts that are used for the power to the fuse box and to other parts of the engine. Most of the wires have a fusible link on the end where they connect to the junction.
You might want to use a solution that looks more elegant, but an easy to reach junction strip with screw posts has its advantages when troubleshooting, or when you need to add a power connection.
Bruce
Old 08-01-2012, 09:54 PM
Thanks
Hey guys, thanks for all the good info. I appreciate the wiring diagram and I have a '90s truck junction block on order. Thanks again, Rod
help wirning junction block Pupsvette76 Electrical 3 02-18-2012 06:01 PM
Junction Block Connector for3300 Electrical 4 03-16-2010 11:11 PM
Junction Block? Where to buy? neverfinishedtoys Electrical 7 03-25-2008 03:06 PM
Accessory Junction Block MI2600 Electrical 1 01-21-2006 03:11 PM
Junction Block Canadian Charlie Electrical 2 07-16-2005 01:45 PM
