breaker
Some light switches have a built in circuit breaker, both lights are overloading one of the breakers. You can check the alternator to bat breaker with out a meter by turning on your lights until one breaker trips then holding your finger on the alternator breaker and you should be able to feel a click when the lights come back on. if it is the light switch breaker you should hear it when the lights come back on . with out Knowing how your system is wired it's hard to do a long range diagonosis, You might need to add a headlight relay. there are several diagrams here on HR in the electrical or on the WIKI information.
You have a resetable breaker,or a relay problem.I'm just guessing that the wire size is to small.I put a head light kit in my sons Toyota an I was amazed at how small the wiring was.Small wire gets hot fast an causes the breaker to heat up and it shuts down,when it cools down it resets it self.Sand the area to bear metal where the ground goes.
I think what you have here is a breaker that is rated below what your headlights are drawing. If you have a 20 AMP breaker and your lights together are drawing 25 amps then your breaker will heat up, pop out, cool down , and then reset again turning itself back on.
If you disconnected one light and the breaker did not pop thats telling you that the breaker,s rating is only enough to handle one light, not two. You are probably going to have to use a headlight relay to overcome the high current draw you have with two headlights.( Tim and others here have suggested also.) If you can follow the diagram i think you will solve your problem. If you have 100 w globes x2, thats 200 /12 = 16 amps current just for two lights. So if other circuits are also using the same breaker then it is overloaded. Ignition circuit maybe 10 or 15 amps. So there is 31 amps with lights and ignition. Try the relay. Al. |
Thanks guys the harness is a EZ-wire 22 circuit same as the painless one.
(I know not really the same) However, the switch does not have a breaker. What really confused me was I didn't install any breakers I'm assuming the fuse/breaker is the one which is coming off the alternator. It looks like a ATC Style Breaker which may only be 20 amps. I forget but need to look if the ATC Style Breaker is on the alternator lead or the fuse block. Because if it is just only on the alternator lead It should not lose power on the whole car, correct? I could up the breaker size but concerned of melting my new ride. (btw it is a 69 camaro) The relay idea is a good one but I guess I need two, one for high and one for low beams? Thanks John |
May help you out:
Relay/Headlights Catalog Relay Kit Catalog Chevy Main wiring Catalog Electric Tech MadElectrical.com - Electrical Tech |
BTW I looked up the power of the lights and they are Bulb Type: H4/60/55W 5000K Super White Color Also here is my baby ![]()
Good job, problem solved easily
Al. |
Good info here too about relays: Custom Cars Classic Hotrods Streetrods-Watsons StreetWorks
| need help electrical problem | lets_baja | Engine | 1 | 02-22-2008 03:45 PM |
| c-10 electrical problem | 47chevrolet | Electrical | 2 | 04-27-2007 07:51 AM |
| Electrical Problem | headturner73 | Engine | 3 | 04-10-2007 09:37 PM |
| electrical problem | dragonboy | Electrical | 1 | 01-22-2007 02:37 PM |
| electrical problem | pintoperformance | Electrical | 2 | 12-12-2003 09:28 AM |
