Electrical Problem with 78 Monza Spyder Fuel Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2011, 03:11 PM
Last journal entry: Albany Oregon Show
I am working on a 78 Monza spider, stock 305 v8 4 speed. The in tank fuel pump stopped working. Checked the fuse and it was blown. Replaced the fuse and still the pump did not work. Bought a new pump and hooked it up to the wiring to test it and no power. Rechecked the fuse and it was good. Hooked my volt meter to wiring at tank and the result was .07 volts. I checked to see if I had 12+ volts when the starter was engaged and still had .07 volts. I checked the battery and I had 12.8 volts at the battery. Checked the voltage at the fuse and It was .07. If I have to I will run another wire from ignition hot to the pump but I wanted to check with you guys and see if I am missing something. Maybe a relay I could not find when I looked or a function of this cars electrical system that allows no power to the pump until it starts.
Bob
Old 06-08-2011, 03:41 PM
Bob
The pump wiring runs through an oil pressure switch. You won't have any power to the pump unless there's oil pressure. Jump across the switch and then see if the pump runs with the key on.
Old 06-09-2011, 09:01 PM
I had one of these cars years ago. The oil pressure switch has 3 lugs on it. The middle one goes to the gauge. The 2 side ones are a normally open switch, they close when the engine has oil pressure. They were used on the Vega and Monza and some early type 3 V.Ws. Kind of a nice safety feature if you lose all your oil pressure the car shuts off.
Old 06-10-2011, 10:09 AM
Originally Posted by plazawag54
I had one of these cars years ago. The oil pressure switch has 3 lugs on it...
Yeah, it looks a lot like this (Standard Motor Products P/N PS64):
Old 06-14-2011, 12:16 PM
Electrical problems
I did check out the sending unit, as shown, there was power to both the side wires???? Given there was power at the sending unit my suspect is the fuse box. I have traced and traced wires and the problem stops at the fuse box. I think it is rusted or corroded. It also looks like a bear to change!! A friend of the owner of the car says he can change it out in two hours. I told the customer it was the best deal in town.
Bob
Old 06-15-2011, 08:06 AM
You said you have power at the sender??? If so then the fuse block isnt the problem. The middle one is for the gauge. One of the sides should have voltage. Is this correct?
Old 06-16-2011, 10:27 AM
Electrical Prob with fuel pump
Yes, both the outside wires have power when key is on??? However at the tank it has only .09 volts. I did jump the two wires even tho they both had 13 + volts at the sending unit???
Old 06-17-2011, 08:12 PM
Thats weird. one wire should be considered a switch leg. In other words it gets its power from the incoming hot, goes through the switch and out to the fuel pump when in obtains oil pressure. If you have volts coming in both sided then you have a short down line between the switch and the pump. you have got a wire crossed somewhere. maybe off of your fuel sender or rear lighting harness. Keep chasing and plese keep me posted. good luck.
Mechanical to Electrical fuel pump Matador813 General Rodding Tech 5 05-24-2011 06:23 PM
problem with fuel pump mrfixid Electrical 1 04-04-2011 06:34 PM
Electrical fuel pump behind mechanical. Duane Johnson Introduce Yourself 3 06-12-2006 10:39 PM
Mechanical or Electrical Fuel Pump lakecityg Engine 5 06-21-2003 10:27 AM
fuel pump problem Tissue Engine 5 06-19-2003 02:14 PM
