Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electrical Problem
Old 04-07-2007, 05:31 PM
headturner73's Avatar
headturner73 headturner73 is offline
Electrical Problem
Hi Guys,,here It Goes,,73 Nova With A 383 ( 350 ) Stroker Had To Replace Intake Gaskets,pulled Dist.out ,,and While I Had It Out I Checked Points For Proper Gap Needing Adj. The Dist. Is A Mallory 2548201 With Double Points #25042x ,, The Points Are 6mo.old And Cap And Rotor, And Plugs,,got It Lined With # 1 Plug,,fired Up And To My Surprise Only Driver Side Had Spark,i Checked To Make Sure I Had Fuel And Plugs Were Wet,checked Cylinders 125 Plus Lbs,i Took A Plug Wire Off Passenger Side Stuck A Spare Plug In But No Spark,could It Be A Bad Set Of Points Or Something In The Dist. I Also Put A New Starter In,turns Over Well,i'm Ready To Go Electronic But I'm Hearing To Many War Stories,,any Help Would Be Gratefull,,thanks Brian
