Electrical Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2007, 10:26 PM
Electrical Question
I need some help with an electrical problem.
When I pull the headlight switch on the temp gauge goes to hot. With the switch off the temp reading is normal and everything runs okay. Any ideas?
Willie496
Old 08-27-2007, 10:32 PM
Wiki Edits: 27
bad ground
You probably have a bad ground. ,,current going the wrong way to find a ground can cause strange things to happen
Old 08-28-2007, 04:19 PM
docvette's Avatar
Wiki Edits: 12
Doc here ,
Check your rear harness going from the dash to the tails..
Chances are you have a cut in the bundle shorting the Fuel sender when the tails are lit..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-30-2007, 12:22 AM
My Blazer had a similar problem -- it was a bad ground to the instrument panel.
My oil gauge and my temp gauge would both change when I pulled on the lights. Ran an additional ground straight from the batt and life was good
ford2go
Old 09-01-2007, 10:58 AM
Electrical Problem
I checked all the ground connections in the consel, and it still will not work. Even when I unhook the themostat green wire from the head the gauge still goes to the hot far right side reading.
Maybe the dash switch is the problem?
Thanks, Willie
Old 09-01-2007, 10:59 AM
ford2go
Thanks, Willie
Old 09-01-2007, 11:00 AM
Originally Posted by docvette
Doc here ,
Doc
Thanks, Willie
Old 09-01-2007, 10:22 PM
kf4ozb's Avatar
Last journal entry: Ignition problems solved
Switch problems
I don't think it's the switch. More likely to be the wires in the wiring harness or ground connections.
Can you provide more detail? How old is the vehcile? Have you made any modifications recently that triggered this symptom? Do your lights work ok, are they dim? Does the gauge read hot if only your parking lights are on, or only when the headlights are on?
The problem definitely sounds like a short. The hardest part is tracking it down.
Old 09-02-2007, 06:11 PM
1969 Camaro, the only modification that I have done we eliminated the regulator by using a single wire altenator. lights work fine they are not dim. The gauge reads hot with the park lights and the headlight switch on.
Old 09-03-2007, 04:02 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Go BACK to where you disconnected the sender from the gauge, then ground that wire (terminal) on the gauge..with the key "On" it should drive to "Full"..
IF it does......
Your Sender wire is cut/shorted..replace it.
Doc
Innovations
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
How To Submit A Post In Electrical Forum docvette Electrical 0 04-25-2006 06:46 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
