electrical questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2011, 12:38 PM
StudebakerDean
I have a part way completed electrical layout completed in a project truck I bought. The fusebox seems wired, the ignition also seems wired. the ga-zillion wires coming from the area of the fuse box all have little numbers on them that coorispond to where they go and I have a diagram of what numbers are what locations.
my question is this. same numbers are on the back of the speedo. so since I would imagine all the long wires go to their locations taillights etc. what goes to the back of the speedo?
Old 07-20-2011, 12:57 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
You will need the instruction book on the speedo you have.
Electric speedos require a sender on the transmission which will have wires that connect to the speedo, usually 3 wires.
The harness will only provide 12 volts ignition ON, ground and instrument light.
vicrod
Old 07-20-2011, 01:14 PM
StudebakerDean
ok, i guess i am thinking long wires w/ numbers matching a book that says their taillights would be taillights... from the fuse box? the speedo has number matching electrical wires and what I would call female connections ends. that wiring kit wouldnt have had long wires to get ot everywhere just to run the foot to the speedo would it?
Engine Swap - Electrical Questions Dougie Engine 4 06-14-2011 08:44 PM
700r4 , lockup converter electrical questions patmckinneyracing Transmission - Rearend 1 06-25-2010 08:47 PM
2 electrical questions for3300 Electrical 3 02-07-2010 11:42 AM
Finding (electrical) shorts questions ChevelleSS_LS6 Electrical 14 12-16-2005 12:48 PM
Electrical knumbskull Electrical 5 08-11-2003 05:31 PM
