electrical speed sensor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2002, 09:05 PM
New Member
Post electrical speed sensor
I am corrently building a 39 Pontiac coupe using an 89 S10 frame rear end and 700 R4 trans mission. I`m hooking up the electronic speedometer, I bought a set of Dolphin gauges. the speedometer has connections for the sensor,ground,ignition and panel lights off the headlight switch. I have two wires coming from the sensor, a green one and a purple one.One is supposed to go to the sensor and one to ground. Anyone familiar with an S10 wiring harness enough to tellme which is which?
if it aint steel it aint real
Old 11-11-2002, 07:48 AM
4 Jaw Chuck's Avatar
Post
Usually green or black would be ground.
— Han Solo
Old 11-11-2002, 07:58 PM
New Member
Talking
Thanks 4jawchuck, I also suspect the purple wire to be a ground. Does anyone know for sure? Would I damage anything if I connected it up backwards? <img src="confused.gif" border="0">
