electrical switch to fan - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-09-2010, 02:10 PM
OLNOLAN's Avatar
Haa
Originally Posted by cobalt327
I'm guessing Australia.
There are alot of Rodders here from Australia, but I ain't gonna guess. Some folks get pissed if you guess wrong.
Sorry bout the hijack MercCat, I try to help when I have the time and chat a bit too. olnolan
  #17 (permalink)
Old 06-09-2010, 03:26 PM
malc's Avatar
Living At The Speed Of Life
Sorry mate but yer wrong, the other ocean.................Atlantic.
  #18 (permalink)
Old 06-10-2010, 09:33 AM
powerrodsmike's Avatar
Wiki Edits: 161
A good reason for using a relay is that you can control a large current with a small current remotely, which means that you only have to run a single small wire from a dash mounted switch to the relay, which can be mounted close to the load...
You can also wire a relay to allow several control inputs, so you could switch a fan on with both a thermal switch, and a dash mounted switch...
I try to avoid bringing high current loads from the engine compartment into the car, especially under the dash..If you ever fried an inadequate switch under your dash you'll appreciate why.
Malc is one of our "global" presences.. One of the few that I'd consider truly "worldly" in his experiences and perspective...
Later, mikey
(on the outside looking in...no matter where I am)
BE different....ACT normal.
changing over to toggle switch for fan cares Electrical 4 02-10-2009 09:49 PM
Electrical fan switch Handy dandy Electrical 4 01-24-2008 08:59 PM
Starter switch stock to modified wiring question. Kallie49 Electrical 5 06-23-2006 06:01 PM
electrical fan surge? stratt134 Electrical 5 06-01-2006 03:11 PM
electric fan temp switch probe, problem 39chevy Electrical 3 08-07-2004 07:28 PM
