Electrical test for 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2005, 05:23 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
I have wired up my 700r4 ;A-12v, B and D to ground and still have no lockup. Are there any tests I can do , to determine if the 4th gear lockup switch is working?
Thanks,
Bob
Old 06-05-2005, 05:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
pull the pan, pressure test the pressure switches with compressed air, use a volt/ohm meter.
40 psi is enough.
unless the wire harness is of the correct configuration , the loop of B to D will not provide lock up
Adheision test. BarryK Body - Exterior 11 04-08-2005 04:01 PM
Reading electrical test meter correctly cboy Electrical 6 07-23-2004 05:13 PM
I.Q. test willys36@aol.com Hotrodders' Lounge 57 11-25-2003 09:34 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 03:39 AM
