The discussion on the 220 volt circuit for compressors reminded me of something I have been meaning to mention but I did not want to high-jack that thread.
Sometimes we use adapters of some sort for electrical devices and often these include a grounding wire that is supposed to be attached to a proper ground but often this is overlooked, an example is those three prong to two prong adapters for older "non-polarized" outlets that have no third hole for the ground prong on plugs equipped with one. Honestly how many of us have actually grounded that wire?
OK, what this is about is that grounding for safety is very important and should not be taken lightly, look that ground over and make SURE it is done right because if you make a mistake it could be serious!
Here's what happened, I set up my new 3 phase 220 volt lathe on a concrete floor and proceeded to wire it to a 220 volt single phase outlet using a static phase converter. I just looked at the sketchy wiring diagram that came with it and it looked simple enough, basically just attach the three wires from the single phase line to the appropriate terminals where the ground wire position was clearly marked then attach the three phase side to the terminals as marked, simple right? What I failed to do was to stand back and visualize this set-up and determine exactly what I done and I just ASSUMED that since I followed the instructions then everything was ok, assuming without verifying can get you hurt! A few months later I was running this machine and a thunderstorm was coming up, no problem I though since I was inside in the dry, the lathe was humming along, I had my radio going and all was well in the world. I vaguely remember a bright blue flash and when I regained my senses I had a terrible ringing in my ears, a distinct taste of Copper in my mouth and both my arms was aching almost unbearably. I noticed there was actually even some smoke in the air in the shop as I sat on the floor trying to figure out what happened, this became obvious once I got up and started looking for the problem. There is a power pole with a transformer right beside the shop and lighting had either flashed very close by or even possibly struck the pole or line but whatever the cause there was a huge power surge that came through and apparently I was the source of grounding between the lathe and the concrete floor!
I had just ASSUMED when I connected the ground wire from the single phase outlet I was grounding the lathe but just by looking at this connection it was very apparent that it in no way made a grounding connection to the lathe itself and any grounding stopped at the converter box, this was very obvious but I failed to look for it because I ASSUMED I was grounding the set-up because I was attaching the ground wire according to the instructions, this was correct for the converter but did nothing to ground the machine and I should have seen that.
The moral to this long story is to NEVER ASSUME ANYTHING! Look over all connections and try to visualize the circuit and make sure the device is properly grounded because while at first it may seem to be there could be a problem and you can't afford to make a mistake here, I did and it hurt!
