Electrical Wiring - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-21-2010, 09:53 PM
DanTwoLakes's Avatar
Wiki Edits: 22
I'm moving this to General Rodding Tech. You all make good points and have good suggestions, and this has gotten beyond the scope of the Interior forum.
Dan
  #17 (permalink)
Old 12-27-2010, 11:00 AM
Zon's Avatar
Zon Zon is offline
Electrical Wizardry
Re: What type of wire?
Originally Posted by A62WAGON
What type of wire(insulation & sizes) are you using? and where do you order it from? Thanks
Wire Gauge is determined by the current draw of the load. Most wires for signaling such as Temperature and Oil pressure Senders are 16 Gauge. Lighting circuits can be also 16 Gauge, but I prefer to use 14 Gauge.
12 Gauge is used for Headlight Relay Feeds and Heater Fans and a 10 Gauge feeds the Fuseblock from the Battery or master shut-off circuit.
I use the largest cable I can find to go from the battery to the starter (#4 at the least) and I make sure I run a ground strap from the battery to the chassis, chassis to the motor and chassis to the body (using multiple ground straps if separate body parts exist such as a truck box and cab).
If I am wiring a pre-50's hot rod I prefer to use the older style cotton-braided wire which I get from The Brillman Company (http://brillman.com/store) and in many of those cases I build my own fuseblock using parts from http://www.wiringproducts.com or other local suppliers in my area.
If I am wiring a 50's or 60's vehicle, I still like to make it more custom and tend to use general harnesses from various manufacturers such as EZ Wiring (http://www.ezwiring.com) and American Autowire (http://shop.americanautowire.com).
Electrical Help Wiring a 1700w invertor Mustangsaly Electrical 10 03-14-2008 10:02 AM
New Member - Wiring and Electrical Specialist ElegantInventor Introduce Yourself 3 08-01-2006 02:31 PM
*glossary Of Basic Electrical Terms* docvette Electrical 2 04-28-2006 07:27 PM
Need Electrical advice, variable speed motor wiring? 327amc Electrical 13 02-01-2006 01:28 PM
Starter Wiring? edit: maybe this should be moved to electrical Tissue Engine 1 02-27-2004 10:51 AM
