Electrolytic rust removal - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-23-2010, 07:16 PM
Joe, i have been useing this process for several years (and many many parts) it works great, but my experience is somewhat contrary to deadbodymans (no offence dead ) the process is very much a "line of sight process" so rust is removed only where the anode and electrode can "see" each other. i have done a few sets of EXPENSEVE headers that have come out like brand new, but had to rearrange the headers and sacrificial electrodes several times so the parts could all "see" each other.
as for the gas bubbles that come off the parts when this is working, the annode and electrode, one emmits oxygen and the other hydrogen (don't remember which is which and who cares ) the important thing is hydrogen burns, so do in a well ventilated area. i set up my tub outside on a corner of the patio and the hydrogen bubbles being much lighter than air just float away.
Joe-your question- the sacrificial metal will not "see" the rings and from my experience will not work, no it will not dissolve aluminum. use a high quality penatrating oil and cover the pistons with maybe 1/8-1/4 inch of oil with the cylinders oriented vertically for a couple of days. after this use a peice of 2x4 on the top of the pistons and whack with a 4 or 8 pound sledge to dislodge the stuck rings, always has worked for me
  #32 (permalink)
Old 08-24-2010, 11:35 AM
I appreciate the suggestions. I'm mainly concerned with getting the worst of the rust off the cylinders above the pistons so I can hammer them out from the bottom. I suspect that I should be able to do that with the electrolytic solution (with moving the electrode) and then use the penetrating oil to free the rings.
  #33 (permalink)
Old 08-24-2010, 04:06 PM
deadbodyman's Avatar
Wiki Edits: 11
I've never done a block before but I would try standing it up so the cylinders are vertical and putting it in the middle of the tank and surround it with 5or6 electrodes on the outer edge of the tank....either way it'll hardly cost anything to find out and it'll only take 24hrs at the most but dont forget to clean of the electrode every 2 hrs or so ,they get caked up pretty fast.It would be interesting to find out how it works let us know if you try it....It should work.
Muriatic Acid Rust Removal 11echo General Rodding Tech 23 03-22-2015 09:48 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
Electrolytic rust removal revisited willys36@aol.com General Rodding Tech 14 10-16-2009 07:45 AM
Rust Removal Tips Riot Racing Body - Exterior 13 10-14-2009 05:46 PM
Rust removal trick(maybe?) oldred Body - Exterior 4 06-27-2005 01:16 PM
