electronic 4 barrel - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2006, 06:41 PM
TroyBoy's Avatar
Psychomotors
electronic 4 barrel
Hey guys ,just bought a 85 Chevy 4x4 w/305 .My question is -if I install a normal 4 bbl. and a normal HEI (non-computerized) will it affect my lock-up in my 700 -4r trans?
Old 08-30-2006, 07:04 PM
Wiki Edits: 31
the computerized HEI and the electronic Q jet only control spark knock, switching to an early pre computer HEI will defeate the need for the computer controlled q jet.
Old 08-30-2006, 11:00 PM
TroyBoy's Avatar
Psychomotors
Don't like current 4bbl.(junk) I'm really only worried about trans lockup as in computer not sending signal to trans because of removal of other parts .
Old 08-30-2006, 11:08 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Is this a FULL blown computer (not module) , with EST Distributer, and TBI?
If so the TCC goes to the RAWL Diode module AND the PPL / Black back to the c2 terminal on the computer AND needs support to operate properly.
So the question is, which is yours?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-30-2006, 11:16 PM
TroyBoy's Avatar
Psychomotors
it is a electronic Q-jet 4bbl.not a TBI.Think it's GM's early attempt at fuel mileage , etc.
Old 08-31-2006, 08:22 AM
Wiki Edits: 31
just spark knock control. If you have a 700 R trans than the lockup is electronicly controlled, but you can bypass it with a lockup switch as long as it's in 4th, summit sellls a kit
Old 08-31-2006, 05:12 PM
docvette's Avatar
Wiki Edits: 12
Doc Here,
OK, the Carb is a 4 EME ..Then..Has a throttle positioner sender on the left front, and a Fuel Solenoid on the right front.
A Switch kit like Matt Suggested will work fine..
Doc
Innovations
Old 09-02-2006, 01:21 AM
TroyBoy's Avatar
Psychomotors
Thanks guys ,I appreciate the info.Didn't think to mention that the engine compartment was all original with smog pump ,hoses running everywhere Gonna put alum.intake and headers on to wake it up a little-Thanks again
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 06:11 AM
4 barrel has less explosive acceleration than my orig. 2 barrel drumharddriveanova Hotrodding Basics 16 11-20-2005 08:42 PM
Can I replace two barrel carb with four barrel on chevy 305 maverick19642001 Engine 6 02-20-2004 11:00 AM
700R4, cruise & electronic speedo 302 Z28 Transmission - Rearend 10 10-31-2003 01:28 PM
Should I run a 2 barrel intake? CrazyT Engine 2 12-08-2002 12:05 AM
